TwinTurbo.NET: Nissan 300ZX forum - I think I found the boost/vacuum leak
Subject I think I found the boost/vacuum leak
Posted by The Silent Genius on April 25, 2010 at 2:20 PM
  This message has been viewed 100 times.
Message Well, I used the boost leak tester and it wouldn't hold pressure long enough to try to listen for leaking air, so I spray carb/choke cleaner around while idling. The brake booster to plenum hose is culprit number one, and I think the upper plenum gasket is culprit number two. I sprayed the carb cleaner down under the plenum at the rear-center and got a reaction in the idle, so unless there is something under there that I'm forgetting, I may be pulling my plenum...again :(
